CLS Easylink 3.0.12 Upgrade *for WoltLab Suite Core 5.2*
The upgrade for your language can be purchased here in the Multimedia Pool Shop.
ACP (Administration) ➽ Customization ➽ Languages ➽ Import language
Upload a language file from the local computer: Select and click the .xml file you downloaded here.
App-main language file: es.xml, pt.xml, pl.xml
