Zaydowicz JCoins – Language Upgrade 5.2.0
    Zaydowicz JCoins 5.2.0 Upgrade *for WoltLab Suite Core 5.2*
    The upgrade for your language can be purchased here in the Multimedia Pool Shop.
    ACP (Administration) Customization Languages Import language
    Upload a language file from the local computer: Select and click the .xml file you downloaded here.
    App-main language file: es.xml, pt.xml, pl.xml
