WoltLab Suite 5.3.0 Upgrade for all Multimedia-Pool translations
The 5.3.0 upgrade for your language can be purchased here in the Multimedia Pool Shop.
ACP (Administration) ➽ Customization ➽ Languages ➽ Import language
Upload a language file from the local computer: Select and click the .xml file you downloaded here.
Main language file: es.xml, pt.xml, pl.xml,
conversation language file (requirements): es.xml, pt.xml, pl.xml
legalNotice language file (optionals): es.xml, pt.xml, pl.xml
App main language file: es.xml, pt.xml, pl.xml
infraction language file (requirements): es.xml, pt.xml, pl.xml
exporter language file (optionals): es.xml, pt.xml, pl.xml
moderatedUserGroup language file (optionals): es.xml, pt.xml, pl.xml
Calendar additional language file eventThread (optionals): es.xml, pt.xml, pl.xml
Filebase additional language file supportThread (optionals): es.xml, pt.xml, pl.xml
ElasticSearch additional language file: es.xml, pt.xml, pl.xml
LDAP additional language file: es.xml, pt.xml, pl.xml
